QOS for 3550 & 3560
trinawong
Dear All,
The significant different for QOS setting between 3550 & 3560, is it 3550 use WRR and 3560 use SRR?
Thank You,
royalblues
Level 10
Level 10
The 3550 switch used WRR as the queuing method. The new switches i.e the 3560 and the 3750 use SRR as the queuing method.
http://www.cisco.com/univercd/cc/td/doc/product/lan/c3550/12225see/scg/swqos.htm
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3560/12225see/scg/swqos.htm
HTH,
Narayan
Hi Narayan,
Thanks a lot for your help. :)
Best Regards,
