Bandwidth command on physical or sub-interface?
Answered Question
Jun 25th, 2007
Hi All,
I am just going through finishing some study but wondering about where the bandwidth command ** should ** be placed?
Should it be specified on the physical interface or sub-interface for routing protocols to calculate the correct metric?
Cheers
Correct Answer by Edison Ortiz about 10 years 1 month ago
Routing protocols run under interfaces with an IP assigned. If the sub-interfaces have the IP, then the bandwidth statement should be there.
Overall Rating: 4.5 (2 ratings)
Correct Answer
Edison Ortiz Mon, 06/25/2007 - 18:42
  • Hall of Fame,
    Founding Member
cameron.moody Mon, 06/25/2007 - 19:22
Thanks EdisonOrtiz
Thats what I thought the answer would be but was 100% sure of it.
Cheers
Cameron
