Can ccm4.2 change the interval between two dialed number ?
i want to change the interval between the first dialed number and the next dialer number ,by default is 2 seconds .i want to 4 seconds ,where should i configure in the CCM4.2?
It is called the T302 timer. The callmanager default is 15seconds. Looks like someone has changed it. Goto CallManager Service Parameters and you will find it there.
It may probably need a cluster wide reboot but you can check to see after the change if a reboot can be ignored.
Learn, share, save
