Catalyst 3560-8PC for CCIE R&S LAB Prep
Jun 25th, 2007
Hi all,
If any one could guide whether Cisco Catalyst 3560-8PC(w/ 8 ports) would be sufficient for CCIE R&S Lab exam preparation. Because a 24 port CAT3560 is too costly....
Cheers,
Akhtar
Overall Rating: 4 (1 ratings)
Edison Ortiz Tue, 06/26/2007 - 12:09
  • Hall of Fame,
    Founding Member
The new compact 3560 switches are perfect for R&S Lab prep. You don't need more than 8 ports to host the routers, backbones and frame-relay.
Also, they support the same IOS features as the 24 port model.
