PIX Subnet issue
Jun 25th, 2007
I have confiured the below command in PIX: nat (inside) 10 192.168.128.0 255.255.252.0 0 0. If I configure system ip 192.168.129.100 subnet 255.255.252.0 GW: 192.168.128.6 (intf IP). Internet is not working. There is no ACL configured in Inside interface.
Overall Rating: 4 (1 ratings)
jgtheodor Mon, 06/25/2007 - 23:28
First of all i suppose you have already added the relevant global command as well as a default route, pointing the PIX outside interface. Could you check it and inform accordingly?
sampathkumar.s Mon, 06/25/2007 - 23:57
Yes. you are right. global (outside) 10 x.x.x.x netmask 255.255.255.248 and default route to this public ip.
timkaye@empired Tue, 06/26/2007 - 01:07
Can u provide an output of " show conn pro tcp local ip.of.inside.host"
ckuriyar74 Tue, 06/26/2007 - 04:28
Try configuring nat (inside) 10 0.0.0.0 0.0.0.0
instead of nat (inside) 10 192.168.128.0 255.255.252.0
Hope this helps. Rate if it does.
Chandru
