Warning message
375-stack configuration
Answered Question
Jun 25th, 2007
Dears,
I have 2 3750 switches required to be stacked. Is there commands to enable stacking ? if there please send me
Correct Answer by royalblues about 10 years 1 month ago
No configurations are required for stack connection.
Just connect the stack cables which came along between the switches.
If you want a certain switch to be a master then you can set the priority
HTH, rate if it does
Narayan
Overall Rating: 4 (1 ratings)
Correct Answer
royalblues Tue, 06/26/2007 - 00:27
  • Green, 3000 points or more
Narayan
