how can i see bgp community ?
Jun 25th, 2007
there are R1 and R2 connected by bgp.
R2 send bgp community as no-export.
in this case, has anyone known how to display community that it exactly set and advertised by command ?
i can see in R1, but i would like to see in R2.
Overall Rating: 2 (1 ratings)
mohammedmahmoud Mon, 06/25/2007 - 23:42
  • Green, 3000 points or more
The community can only be viewed on the router receiving the tagged route, and not on the router setting the community.
HTH,
Mohammed Mahmoud.
royalblues Tue, 06/26/2007 - 00:00
Friend,
The no-export and no-advertise community instructs the neighbor whether to either advertise it to internal bgp peers or external ebgp peers.
Hence this is shown on the neighbor and not on the router setting it
HTH, rate if it does
Narayan
