Policy Routing on Catalyst 3560
Jun 25th, 2007
PBR is configured on a Cisco Catalyst 3560 Switch.
The Switch is running with c3560-ipservices-mz.122-25.SEE2/c3560-ipservices-mz.122-25.SEE2.bin" Image. However while applying the PBR on the vlan interface, though it takes the command.
However the command doesn't get applied on the vlan interface ( show running)
Does SDM prefer routing command will resolve the problem or is there any other solution.
mohammedmahmoud Mon, 06/25/2007 - 23:48
Your IOS supports PBR as per the Cisco feature navigator, and thus it should work, have you "ip routing" configured.
HTH,
Mohammed Mahmoud.
royalblues Tue, 06/26/2007 - 00:12
I think you would require the SDM prefer routinmg command to use policy routing
Narayan
