Problem configuring 1721 router
Jun 26th, 2007
I have to configure a cisco 1721 with NAT
this is the config :
sh run
Building configuration...
Current configuration : 1899 bytes
version 12.3
service timestamps debug uptime
service timestamps log uptime
hostname ByPass_LinkProof
enable secret 5 ##############
no aaa new-model
ip subnet-zero
no ip domain lookup
ip cef
interface FastEthernet0
ip address 192.168.152.2 255.255.255.0
ip nat inside
speed 100
full-duplex
interface FastEthernet1
switchport access vlan 2
no ip address
interface FastEthernet2
switchport access vlan 3
no ip address
interface FastEthernet3
switchport access vlan 4
no ip address
interface FastEthernet4
switchport access vlan 5
no ip address
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address <Pub Address 1> 255.255.255.248
ip nat outside
interface Vlan3
ip address <Pub Address 2> 255.255.255.240
interface Vlan4
ip address <Pub Address 3> 255.255.255.248
interface Vlan5
ip address <Pub Address 4> 255.255.255.248
ip nat inside source list 1 interface Vlan2 overload
ip nat inside source static 192.168.151.3 <Pub Address 5>
ip nat inside source static 192.168.151.4 <Pub Address 6>
ip classless
ip route 0.0.0.0 0.0.0.0 <NHR Address 1>
ip route 10.242.0.0 255.255.0.0 192.168.152.1
ip route 192.168.150.0 255.255.255.0 192.168.152.1
ip route 192.168.151.0 255.255.255.0 192.168.152.1
no ip http server
access-list 1 permit any
access-list 101 permit tcp any any eq www
access-list 101 permit tcp any any eq domain
access-list 101 permit tcp any any eq 3101
access-list 101 permit tcp any any eq smtp
access-list 101 permit tcp any any eq pop3
access-list 101 permit tcp any any eq 443
access-list 101 permit tcp any any eq 22
access-list 101 permit tcp any any eq 995
access-list 101 deny tcp any any
access-list 102 deny tcp any eq 445 host 192.168.0.103
access-list 102 permit tcp any any
line con 0
line aux 0
line vty 0 4
password #####
login
no scheduler allocate
end
ByPass_LinkProof#
The Vlans 3 4 and 5 are note used for the momment.
when he router is connecter I can ping an internet ip on the router, but not inside the network.
thanks for your help.
Richard Burts Tue, 06/26/2007 - 04:16
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Adrien
I do not see any particular issue with the configuration of NAT and wonder if there is some other explanation for your problem. Is it possible that the end stations inside the network do not have correct default gateway configured? (for example can the end stations access resources in the 192.168.150.0 and 192.168.151.0 networks?) Or is it possible that you are pinging by address from the router and pinging by name from the inside end station and there is some issue with DNS?
I see access list 101 and 102 configured (and believe that there are some issues with these access lists) but do not see them applied. Can you clarify what is being done with these access lists?
Rick
ricadri640 Tue, 06/26/2007 - 04:36
The acl 101 and 102 where not in use, so I delete...
this is the config now, with the same problem :
sh run
Current configuration : 1461 bytes
version 12.3
enable secret 5 ###################
no aaa new-model
ip subnet-zero
no ip domain lookup
ip cef
ip nat inside
speed 100
full-duplex
no ip address
no ip address
no ip address
no ip address
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address 255.255.255.248
ip nat outside
interface Vlan3
ip address ############# 255.255.255.240
shutdown
interface Vlan4
ip address ############# 255.255.255.248
shutdown
interface Vlan5
ip address ############## 255.255.255.248
shutdown
ip classless
no ip http server
line con 0
line aux 0
line vty 0 4
password #############
login
end
ByPass_LinkProof#
it is not a problem of internal configuration, because with another device it works well...
thanks
