Configuring 1721 with NAT
Answered Question
Jun 26th, 2007
I have to configure a cisco 1721 with NAT
this is the config :
sh run
Building configuration...
Current configuration : 1899 bytes
version 12.3
service timestamps debug uptime
service timestamps log uptime
hostname ByPass_LinkProof
enable secret 5 ##############
no aaa new-model
ip subnet-zero
no ip domain lookup
ip cef
interface FastEthernet0
ip address 192.168.152.2 255.255.255.0
ip nat inside
speed 100
full-duplex
interface FastEthernet1
switchport access vlan 2
no ip address
interface FastEthernet2
switchport access vlan 3
no ip address
interface FastEthernet3
switchport access vlan 4
no ip address
interface FastEthernet4
switchport access vlan 5
no ip address
interface Vlan1
no ip address
shutdown
interface Vlan2
ip address <Pub Address 1> 255.255.255.248
ip nat outside
interface Vlan3
ip address <Pub Address 2> 255.255.255.240
interface Vlan4
ip address <Pub Address 3> 255.255.255.248
interface Vlan5
ip address <Pub Address 4> 255.255.255.248
ip nat inside source list 1 interface Vlan2 overload
ip nat inside source static 192.168.151.3 <Pub Address 5>
ip nat inside source static 192.168.151.4 <Pub Address 6>
ip classless
ip route 0.0.0.0 0.0.0.0 <NHR Address 1>
ip route 10.242.0.0 255.255.0.0 192.168.152.1
ip route 192.168.150.0 255.255.255.0 192.168.152.1
ip route 192.168.151.0 255.255.255.0 192.168.152.1
no ip http server
access-list 1 permit any
access-list 101 permit tcp any any eq www
access-list 101 permit tcp any any eq domain
access-list 101 permit tcp any any eq 3101
access-list 101 permit tcp any any eq smtp
access-list 101 permit tcp any any eq pop3
access-list 101 permit tcp any any eq 443
access-list 101 permit tcp any any eq 22
access-list 101 permit tcp any any eq 995
access-list 101 deny tcp any any
access-list 102 deny tcp any eq 445 host 192.168.0.103
access-list 102 permit tcp any any
line con 0
line aux 0
line vty 0 4
password #####
login
no scheduler allocate
end
ByPass_LinkProof#
The Vlans 3 4 and 5 are note used for the momment.
when he router is connecter I can ping an internet ip on the router, but not inside the network.
thanks for your help.
Correct Answer by Paolo Bevilacqua about 9 years 8 months ago
Hi, please change access-list 1 to include all the subnets "inside" that you want to go on the Internet and no not use the "permit any". After that, try telnet from internet to outside interface. If it fails, you will an extended-access list instead of standard one.
Overall Rating: 5 (1 ratings)
Correct Answer
Paolo Bevilacqua Tue, 06/26/2007 - 04:27
