Find the System Serial nr on a 2651XM
Answered Question
Jun 26th, 2007
Is it another method than sh ver? Running sh ver, does nor report the system serial nr,and i need that for TAC supp,
Correct Answer by royalblues about 9 years 3 months ago
Yes it has one but you need physical access to see it :-)
Overall Rating: 2.9 (8 ratings)
royalblues Tue, 06/26/2007 - 03:36
Unfortunately the 2600 series do not report the chassis serial number with any command
All the new ISR routers and switches report the chassis serial number in the "sh inventory" command.
BTW if you have the contract ID, you should be able to raise a TAC case
Alf Martinsen Tue, 06/26/2007 - 04:02
Thanks both of you. Well i dont need it only for a TAC case, but more for a SLA against a wendor. We are running IOS 12.2 so sh inv is not available.
I would here what Cisco wants from me on this one.
mohammedmahmoud Tue, 06/26/2007 - 04:04
Totally agree with Narayan, "show inventory" is not even available for the 2600 series.
Mohammed Mahmoud.
royalblues Tue, 06/26/2007 - 04:07
The command is available as a part of the new IOS feature.
But when you use this command on a 26xx, it will show the processor ID and not the chassis serial number.
Correct Answer
royalblues Tue, 06/26/2007 - 04:27
Alf Martinsen Tue, 06/26/2007 - 04:55
OK, then i have to walk 200 m :-) Ok i'l give you all a 2 ones for this, fair?
Pavel Bykov Tue, 06/26/2007 - 08:18
Yup, good old fasion way of walking to the router and looking at the sticker with SN on it.
Also, if you have your order/delivery lists saved, then you can get SN's from there.
guruprasadr Tue, 06/26/2007 - 20:25
HI Narayan,
Thanks for Info. But, i was trying to locate the Device Model / IOS Version that Supports "show inventory" command.
But no results found. Thanks again for Info.
Best Regards,
Guru Prasad R
mlitka Wed, 06/27/2007 - 05:35
From what I have seen show inventory is just a cleaned up version of show diag. I believe they report basically the same information. What has changed is that the chassis serial number is now being reported instead of the motherboard serial number.
laitonglek Mon, 07/02/2007 - 17:01
Dear Amrtinsen,
I think by using the "sh diag" command you able to see the serial number including the chassis, and the WIC as well.
