Compression Card AIM0 is not Compatible with Cisco 3825
Answered Question
Jun 26th, 2007
Guys,
I have Cisco 3825 having some compatibility problem with its AIM0 slot. I m gonna use hardware compression card i.e AIMR-V2. This card was working with Cisco 2811. Now i moved this to Cisco 3825. After putting it into Cisco 3825 router, card is detecting by the router but AIM0 LED showing Amber light. Which shows the Incompatibility. When i check the SH VER and SH DIAG , there is no Card installed. In my SDM, I am getting the Error of compatibility.
If any one idae.,than revert back
Correct Answer by paolo bevilacqua about 9 years 10 months ago
Which IOS did had on the 2811, and which do you have on the 3825 ?
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Tue, 06/26/2007 - 04:11
  • Hall of Fame,
    Founding Member
royalblues Tue, 06/26/2007 - 04:16
  • Green, 3000 points or more
THere are 2 AIM slots in a 3825. Can you try installing the same on the other slot and check?
Narayan
youngofficer Tue, 06/26/2007 - 04:22
Yes I tried with both AIM slots. Not workign on both slots.
Let me check the compatibility chart also.
