ftp custom script to /script on CSS11503
Jun 26th, 2007
I used tftp successfully. When I ran script ap-kal-tcp-ports both ports opened however I received error at end
Error could not remove variable.
I'm using TACACS and not allowed local accounts. I can ftp to CSS but cannot drop custom script in directory. What am I missing?
Overall Rating: 5 (1 ratings)
RODRGUTI Mon, 07/02/2007 - 16:54
You can try this:
- copy the script in a notepad file. After you saved the file, please delete the extention of the file (get ride of the .txt)
- Put it on C:\ drive.
The open a cmd prompt:
C:\dir (make sure that you have the file there)
C:\ ftp 1.1.1.1 (CSS circuit vlan IP address)
Here you need to login with you CSS username and password.
ftp> bin (hit enter)
ftp> hash (hit enter)
ftp> cd script (hit enter)
ftp> put tcp-ports (hit enter)
Now we have the script into the CSS ready to be used on your keepalive.
If you follow the steps everything should work fine.
Hope this make sense.
- Rodrigo
