Reason Code Number
Jun 26th, 2007
Can anyone tell me what each of these IPCCX reason codes can be described as
Reason Code 32,756
Reason Code 32,757
Reason Code 32,758
Reason Code 32,759
Reason Code 32,760
Reason Code 32,761
Reason Code 32,762
Reason Code 32,763
is there a way to report on all user defined reason codes as well?
Aaron Harrison Tue, 07/19/2011 - 02:27
  • Community Spotlight Award,
    Member's Choice, May 2015
Page 49 onwards of this guide has the codes listed : http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_8_0/user/guide/cda80ccxug-cm.pdf
In terms of reporting, it's possible to go to the 'detailed' tab of the Agent Not Ready Reason Code Summary report, and select 'Reason Code' as the filter. You can then multi-select reason codes you want to appear.
Aaron
Please rate helpful posts...
