srue Tue, 06/26/2007 - 05:14
it depends really...
are you opening it to a device on the inside that has a static NAT entry? are you overloading (w/ PAT) that outside interface?
I don't use PDM but here's the CLI version:
access-list outside_acl permit tcp/udp any host inside_host eq 3306
access-group outside_acl in interface outside
depending on your NAT configuration, this might vary a little.
leaseboy1 Tue, 06/26/2007 - 05:26
I appreciate your response, but it's all a foreign language to me.
