Switch 2950 password
Jun 26th, 2007
Dear All
I configured cisco S/W 2950-24ports and changed the default ip from to, now i want to manage the switch from explore by pointing to this new IP. it prompt for level 15 user name and password. can any one let me know what is the default user name and passwor for the switch
appreciate your reply
sundar.palaniappan Tue, 06/26/2007 - 06:42
I believe the newer Cisco equipment comes preconfigured from factory with a local username/password combination of cisco/cisco. I don't know that's the case here. If it isn't then password recovery is the only option.
farkascsgy Tue, 06/26/2007 - 06:46
You are totally right, but this is an 2950 switch.
Default passwords can be:
as Sundar wrote.
Please rate me if I helped.
glen.grant Tue, 06/26/2007 - 07:28
there is no default username and password on a 2950 it would have been specifically configured on the 2950 by someone . Some devices like the 2800 series do come with a username and paswword on it , haven't figured out the point of that right out of the box and its cisco/cisco . You will probably have to do a password recovery if you can't figure it out.
