Agents getting calls while on the phone
Anonymous (not verified) Tue, 07/03/2007 - 10:05
Check if you are trying to change the state to ready state manually while on call? If not you might be hitting the known issue CSCee00813.
Mormegill Sun, 07/15/2007 - 23:24
Bruce,
We have a customer running IPCC Ent and CAD. After an upgrade to IPCC v7.1 this february we have encountered issues with agents getting inbound customer calls while already talking (i.e. in state Talking). We haven not had any issues with calls after logout though.
We've a TAC case on the issue, but no solution as of yet.
Mormegill
Justin Brenton Wed, 08/08/2007 - 22:43
  • Silver, 250 points or more
What is your max calls and busy triggers set to on the phone's in CCM?
gtechfred01 Thu, 08/09/2007 - 08:04
If you are using auto answer your Busy Trigger needs to be set to 1.
Justin Brenton Tue, 08/21/2007 - 06:51
Maximum Number of Calls* (1 - 196)
Set to 2
Busy Trigger* (<= Max. Calls)
Set to 1
Hope this helps. Be weary at what lines you assign this to, are you using just 1 ICD ext on the phone or a ICD ext and a regular extension?
