Anyconnect and VPN3000
Jun 26th, 2007
Anyconnect it is envisaged on the VPN3000, or I replace my VPN3030 by another product?
Overall Rating: 4 (2 ratings)
ggilbert Wed, 06/27/2007 - 04:51
Anyconnect is only for the ASA platform. Its the replacement of the SSL VPN client for the ASA platform.
At the moment, the anyconnect client doesnt support IPSec. It does support DTLS and TLS modes. In the future release, anyconnect will support IPSec.
Rate this post, if it helps.
adonnat Wed, 06/27/2007 - 05:06
Hello Gilbert,
I don't understand... On my VPN3030, SSL VPN Client (SVC) use 3DES-168 TLSv1 and no IPSec. Mode configuration for encryption don't exist for VPN3000 and fixed with 3DES-168 TLSv1.
When anyconnect Client will be OK with VPN3000?
ggilbert Wed, 06/27/2007 - 05:12
Anyconnect will not be supported with VPN3K.
VPN 3K has been End of Life and I believe there is no future enhancements that will be made to the VPN 3K concentrator for the Anyconnect client.
adonnat Wed, 06/27/2007 - 05:22
OK, if Cisco decides to stop the development on VPN3000, I change my concentrator by another company that Cisco. I didn't buy a ASA.
