Adding routers to home network
patrickpaez
I'm adding three routers to my home network, however I'm having trouble getting the routers to recognize the network. I have a core router connected to the home network via e0 and the other routers are linked via back to back cables to the core router. The core router can see the home network, however the other two routers cannot see anything past e0 on the core router. The home network is using 192.168.0.x, while the routers are using 10.x.x.x with e0 being 192.168.0.100.
I've tried using default network 192.168.0.0 in eigrp settings. It propogates the information to the other routers, but traceroutes continue to stop at the core router.
I've also tried using a static route, with distribute static in eigrp routing with no luck.
The only thing that seems to work is using the nat method. If you setup the default route, shouldn't this method work? or is there something I'm missing?
Thanks in advance
7 Replies 7
royalblues
Level 10
Level 10
Can you post your netowrk topology
Narayan
I've attached a jpg of the network topology. Sorry for it's crudeness. If it's no ledgeable, I'll create a better one when I get home tonight.
With EIGRP
on router with seg 10.10.10.2/30
router eigrp 100
network 10.10.10.0 0.0.0.3
no auto-summary
on router with seg 10.10.10.1/30
router eigrp 100
network 10.10.10.8 0.0.0.3
no auto-summary
on router with seg 10.10.10.9/30
router eigrp 100
network 192.168.0.0 0.0.0.255
no auto-summary
with static routes
ip route 10.10.10.8 255.255.255.252 10.10.10.1
ip route 192.268.0.100 255.255.255.0 10.10.10.1
ip route 192.268.0.100 255.255.255.0 10.10.10.9
ip route 10.10.10.0 255.255.255.252 10.10.10.10
HTH, rate if it does
Narayan
Thanks for the info, but I've already tried the solution with eigrp.
This is the output I get from 10.10.10.1:
kuyaz2>sh ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, * - candidate default
Gateway of last resort is 10.10.10.9 to network 192.168.0.0
10.0.0.0 is variably subnetted, 3 subnets, 2 masks
C 10.10.10.8 255.255.255.252 is directly connected, Serial0
C 10.10.10.0 255.255.255.252 is directly connected, Serial1
D 10.10.100.0 255.255.255.0
[90/2195456] via 10.10.10.2, 00:09:25, Serial1
D* 192.168.0.0 [90/2195456] via 10.10.10.9, 00:09:25, Serial0
As the output indicates, it recognizes the default gateway being out 10.10.10.10
Are you using the default-network command in the configurations.
Can you post your configurations
Narayan
When I set default network under eigrp 101, network 192.168.0.0 does not get advertised. The configuration of segment 10.10.10.9 is below.
Current configuration:
version 12.0
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname kuyaz3
enable secret *****
ip subnet-zero
ip name-server 192.168.0.1
interface Ethernet0
ip address 192.168.0.100 255.255.255.0
no ip directed-broadcast
interface Ethernet1
no ip address
shutdown
interface Serial0
no ip address
shutdown
interface Serial1
ip address 10.10.10.9 255.255.255.252
router eigrp 101
network 10.0.0.0
network 192.168.0.0
ip classless
Edison Ortiz
If your destination address is out on the internet, you must NAT the source network (10.0.0.0) the same way you are NAT'ng the 192.168.0.0 network - routing alone won't do it since the internet has no way of knowing the 10.0.0.0 is coming from you.
