VPN and NAT between PIX and sonicwall TZ170
Jun 26th, 2007
I'm trying to create a site to site vpn between a pix 520 and a sonicwall tz170. The Problem is that both sides use on the inside, so, i have to use NAT.
they only need to reach some addresses in the range so i only need to nat from my side to their side.
the Tunnel comes up and I receive packets, but i never see packets encapsulated on my side.
the setup is
relevant config :
access-list SAP_oasis extended permit ip
global (outside) 1
nat (inside) 1
static (outside,inside) netmask
route outside 1
route inside 1
crypto ipsec transform-set aes-256_sha esp-aes-256 esp-sha-hmac
crypto map VPN 10 match address SAP_oasis
crypto map VPN 10 set peer
crypto map VPN 10 set transform-set aes-256_sha
crypto map VPN interface outside
isakmp identity address
isakmp enable outside
isakmp policy 13 authentication pre-share
isakmp policy 13 encryption aes-256
isakmp policy 13 hash sha
isakmp policy 13 group 2
isakmp policy 13 lifetime 28800
isakmp policy 65535 authentication pre-share
isakmp policy 65535 encryption 3des
isakmp policy 65535 hash sha
isakmp policy 65535 group 2
isakmp policy 65535 lifetime 86400
tunnel-group type ipsec-l2l
tunnel-group ipsec-attributes
pre-shared-key *
Can anybody help me out ?
James.Ren Wed, 06/27/2007 - 03:44
Hi there,
I think the problem might be caused by your NAT in the security appliance. When your defined VPN traffic went through your PIX, it was translated to another destination address thus it failed to meet your SAP_oasis.
You need to user NAT 0 to exempt the VPN traffic from being translated.
Hope it helps.
James Ren
be04376 Wed, 06/27/2007 - 05:03
thx he was doing 2 times nat
i excluded nat for the translated range and it works
