CallManager MoH limitations
Jun 26th, 2007
I have a customer who is receiving the following error message from his single server deployment: Number of MediaListExhausted events exceed 0 within 60 minutes.
Any idea if he is reaching a limitation on unicast MoH streams or is this caused by something else?
neesharm Tue, 06/26/2007 - 09:40
  • Bronze, 100 points or more
Check if the users dialing incorrect numbers often ( a number which does not exists )
Unless you are receiving reports that outbound calls are not
completing you can choose to ignore them
Medialist exhausted means that callmanager has gone through all devices
in the Media Resource Group and was not able to assign a device to use.
Now, if you want to stop receiving these messages, you can log in to RTMT and click on
the Alert Menu> Set alert properties>select the alerts you are getting and uncheck
the Enable Alert box or selecting the alert type, for example, MediaListExhausted and
clcik next, then you will be able to configure a Threshold to trigger the alert only when
the number of MediaListExhausted events exceed a certain number within an hour. This will
reduce the number of alters you are getting.
