Voice Gateway not allowing outside calls to IP Phones
Jun 26th, 2007
My current setup is:
2851 Gateway with a 4 fxo card installed
PBX phone line plugged into port 0/0/0
CCM v 5.1
I can call any internal office number and any off site local or long distance number from my IP Phone through the PBX with no problems but when I try to call an IP Phone say DN 3000 I get one ring then a busy signal.
I tried adding the PLAR 3000 command to voice-port 0/0/0 and that did not help.
I have all my route patterns running on the CCM
I am using MGCP
vmoopeung Mon, 07/02/2007 - 14:00
Could you please do a CCM trace and see whether the dialled didgits are sent with the appropriate prefix
Paolo Bevilacqua Mon, 07/02/2007 - 14:11
Well the thing is that because from the point of view of the PBX the router is just an extension, PBX will never outpulse any digit.
And I think the connection plar won't work because you have configured MGCP.
If you want to make a serious bidirectional integration with the PBX, you need to use some digital card like ISDN BRI, PRI, at very minimum E&M.
Or, configure CCM to that when PBX rings the FXO port, it does something. The alternative is H.323 for the gateway, and have use connection plar (opx) to dial a single extension.
