NTP on MPE
Answered Question
Jun 26th, 2007
How do you configure/start NTP on Meeting Place Express? I keep having to reset the time. Today it was 20 minutes behind and caused all kind of havoc. :P
Correct Answer by thisisshanky about 9 years 11 months ago
Jones,
From MPX desktop or remote ssh into a shell session on MPX server. Type "net".
A menu with lot of options will show up and then you can choose option 8 to configure NTP service.
Once you change the settings, save it when the menu prompts and reboot the server.
Sankar
PS: please remember to rate posts!
Overall Rating: 5 (2 ratings)
Correct Answer
thisisshanky Tue, 06/26/2007 - 12:45
  • Purple, 4500 points or more
Jones,
Sankar
david.mackill Mon, 09/15/2008 - 20:06
I have done this and it still is not syncing. I can ping the NTP server from the MPX server
I have checked the /etc/ntp.conf and it shows the ntp server listed there as well.
lstoked Tue, 04/28/2009 - 05:45
Did you ever get the ntp to sync on mpe?
david.mackill Tue, 04/28/2009 - 12:17
Yes - we had to log a TAC case to resolve this in the end. We also had to update the MPE version.
