splitting an EtherChannel
Jun 26th, 2007
I have configured an EtherChannel to use PAgP over several fibre links from one site to another.
I have x2 1gig lines which I have EtherChanneled, I want to configure VLAN10 to take 75% of the bandwidth, and VLAN20 the remaining 25%.
How do I configure this?
sundar.palaniappan Tue, 06/26/2007 - 13:04
  • Green, 3000 points or more
AFAIK etherchannel doesn't support that sort of granularity in managing the flow of traffic in a direct way. Etherchannel supports load balancing based on individual or combination of MAC/IP/Port info. You might be able to influence the flow of traffic indirectly by choosing the right load balancing method by studying the physical interface stats.
http://cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a0080160a03.html#wp1020436
Sundar
cisco-pix Tue, 06/26/2007 - 13:44
Is there any other way I can segment my connection in this way?
Or at least guaranttee a certain VLAN is given a fast connection, over the other VLANs on the trunk?
