Centralized CM4.23sr1 with Distributed Unity 4.x
Jun 26th, 2007
  • Bronze, 100 points or more
I currently have a topology with Centralized CM4.2.3sr1 with a planned 2 Distributed UM 4.2.1 (no failover) one located in Calif and other in New Jersey
and
1 UM4.0.4 located in London, UK
All 3 Unity will be digital network. Here's my concern
The 1st Unity server (ie name Unity1) will have default
EAdmin acct
AllSubscriber DistributionList
The 2nd Unity server (ie Unity2) will have the same defaults
EAdmin acct
The 3rd Unity server (ie Unity3) will have the same defaults
EAdmin acct
What will happen as these are duplicate (actually triplicate) accts which will create a conflict.
See error below:
1233:(error) the extension number for this object conflicts with one or more objects in the directory
All objects found to be using extension #99999:
Subscriber with a display name=Example Administrator - UNITY2
Subscriber with a display name=Example Administrator - UNITY1
Alias=allsubscribers
Display name=All Subscribers - UNITY1
Extension= 99991
All objects found to be using extension #99991:
Distribution List with a display name=All Subscribers - UNITY1
Distribution List with a display name=All Subscribers - UNITY2
Also, in the future, how do I avoid this if I was to install a 4th Unity?
TIA
Ginger Dillon Wed, 06/27/2007 - 11:11
  • Blue, 1500 points or more
Hi -
We have a similar environment as you do, centralized CallManager and 5 digitally networked Unity servers. Four Unity servers are in different domains. Although the EAdmin and DLs are created when you install a new Unity server, Active Directory takes care of this OK. The accounts, if you look at them in ADUC, will each have unique email addresses, such as allsubscribers, allsubscribers1, allsubscribers2 and so on. It's just DBWalker that complains because the phone extension is not unique. You can correct this by assigning different extensions, using your dial plan, to each of the Unity EAdmin accounts and DLs. However, I can tell you from experience, these accounts do not call each other. Your CTI route point DNs are used for digital networking between Unity servers. Hope this helps!
Ginger
