06-26-2007 06:04 PM - edited 03-03-2019 05:37 PM
Hello everybody;
i have enabled per-destination load balancing, and CEF for sake of my applications as follow :
ip cef load-sharing algorithm include-ports source destination
it works very well. but when i see the traffic on the links i see diffrences between them as following:
Interface IHQ IQD OHQ OQD RXBS RXPS TXBS TXPS TRTL
* Serial2/0:0 0 0 0 367927 204000 328 145000 244 0
* Serial2/1:0 0 0 0 607751 39000 68 29000 58 0
* Serial3/0 0 0 0 475583 417000 731 346000 626 0
seial3/0 if 2 PVCs each one is 2048Kbps
my concern is about serial2/0 and seial2/1 ,, as they are identical even in provider path to my remote end. and both of them are E1 conn.
can anyone explain to me why i see that diff. ?
Regards //
06-26-2007 09:22 PM
may be this link will help you.
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094820.shtml
Mahmood
06-26-2007 11:11 PM
Hi Mahmoud,
This is normal as per destination load-sharing doesn't equally share the bandwidth, and thus its normal to have different bandwidth utilization on the links.
HTH,
Mohammed Mahmoud.
