802.1Q trunk between 2950 and extreme
Jun 26th, 2007
Dears
I have cisco 2950 switch and extreme switch. I have little experiance in extreme switch if any one has documentaion regarding this issue please send me especially configuration on extreme switch
Amit Singh Wed, 06/27/2007 - 09:14
  • Cisco Employee,
I have worked a little less on this config and just to share my experience, you have to tag all the vlans manually on the extreme's trunk port connecting to the Cisco 2950. Cisco 2950 bydefault has Vlan1 as the native vlan on the trunkports, so you have to make a dummy vlan on the switch and configure it as the trunk native vlan. This will make sure that your all the vlans are tagged on the trunk vlan connected to the extreme switchports.
HTH,please rate if it does.
-amit singh
amit_kulshrestha_2 Mon, 07/09/2007 - 20:21
Can you give exact detail of extreme switch ,like model and config .i will try to help you out with your problem.
