06-26-2007 11:20 PM - edited 03-11-2019 03:36 AM
Hi all,
Does Pix 525 with code 7.2 support jumbo frames? Any one running Pix with mtu set to 9000?
John
Solved! Go to Solution.
06-28-2007 05:11 PM
As stated earlier, wiseman GE cards (32bit, 33 MHz) does not support Jumbo packets. They can be set to 1500 max mtu.
Vibhor.
06-27-2007 06:57 AM
Pix with livengood GE-cards (64bit, 66 MHz) do support the jumbo packets. They should run pix version 5.3.1 and above.
The Jumbo parket size can upto 16K. If you want to use the Jumbo packet you need to set the "mtu" of the GE nic to 16000. Its recommended not to exceed 16000.
Note: The wiseman GE cards (32bit, 33 MHz) does not support Jumbo packets.
Hope this helps.
Vibhor.
06-28-2007 02:40 PM
Hi Vibhor.
Thanks for your help. how do i know if i have livengood GE-cards (64bit, 66 MHz) without opening the pix. The gig card i have are as follows:
Interface GigabitEthernet0
Hardware is i82542 rev03, BW 1000 Mbps
Interface GigabitEthernet1
John
06-28-2007 02:47 PM
If show interface is showing i82542, then these are 33MHz Wiseman cards.
66MHz Livengood version will show up as i82543.
Thus, as per the current output, it seems that you have 33MHz Wiseman cards.
Hope this helps.
Vibhor.
06-28-2007 05:04 PM
What is the largest mtu supported by the 33MHz Wiseman cards?
John
06-28-2007 05:11 PM
Vibhor.
06-28-2007 05:25 PM
Thanks a lot for your time.
John
