cdp
Answered Question
Jun 27th, 2007
i was thinking cdp passes only by native vlan (by default vlan1). but my computer is connected to a port configured in vlan 111 and it still receive cdp. is this normal?
Correct Answer by mohammedmahmoud about 9 years 8 months ago
CDP is not restricted to Native VLAN, Each CDP-configured device sends periodic messages to a multicast address, but the question is how do you receive the CDP packets on your PC ?
HTH,
Mohammed Mahmoud.
Overall Rating: 5 (1 ratings)
Correct Answer
mohammedmahmoud Wed, 06/27/2007 - 01:05
HTH,
Mohammed Mahmoud.
srue Wed, 06/27/2007 - 05:20
on the switchport interface that you don't want cdp enabled on, enter the following command:
no cdp enable
or to globally disable cdp, enter:
no cdp run
