MARS Incident Severity
cashqoo
How does MARS define or calculate Incident Severity?
-Low (green)
-medium (yellow)
-high (red)
is it the same as IPS Risk rating?
Thanks in advance.
cash
mogli
it seems that the severity of a particular incident is derived form the severities of the fired events that lead to the incident (due to matching in a rule).
the pre-defined events have already pre-defined severities (Management -> Event Management). They can not be edited.
If you are defining Custom Events you can set the severity to the level you like.
hope this helps,
br
