vtp password
Answered Question
Jun 27th, 2007
  • Silver, 250 points or more
hello
suppose i need to add a new switch to an existing network, but no one knows the vtp password. is there a way to know it? or should i reconfigure it in all switches?
Correct Answer by mohammedmahmoud about 9 years 9 months ago
On one of your switches do this:
Switch#show vtp password
VTP Password:xxxx
HTH,
Mohammed Mahmoud.
Overall Rating: 5 (3 ratings)
mheusing Wed, 06/27/2007 - 00:51
  • Cisco Employee,
The best situation is to know the VTP password. So changing it during the next maintainance window will be the best solution.
As a quick and dirty workaround you could copy the vlan.dat file from an existing switch in your production environment into the new switch in a lab environment, as it contains the VTP config. Then do a manual cleanup BEFORE you add the switch to the existing network. Make sure you follow the guidelines described in the "Configuring VTP" section of the appropriate configuration guide when adding the new switch to your network.
Regards, Martin
Wassim Aouadi Thu, 02/21/2013 - 04:49
Martin, could you elaborate on the sentence "Then do a manual cleanup BEFORE you add the switch" ?
Correct Answer
mohammedmahmoud Wed, 06/27/2007 - 00:55
  • Green, 3000 points or more
VTP Password:xxxx
HTH,
Mohammed Mahmoud.
ohassairi Wed, 06/27/2007 - 01:15
thanks all
ok mohammed, but this seems to be a new introduced command, because in my current (old)switches: cisco WS-C3548-XL ( Version 12.0(5)WC10) this command does not exist.
CS-BR-EG-03#sho vtp ?
counters VTP statistics
status VTP domain status
mohammedmahmoud Wed, 06/27/2007 - 02:43
Ok, you are right, i tried it on one of my old 3548-XL and it didn't work, but you can do the following:
3500#more flash:vlan.dat
and you can find the password in the second line of the output (note that the output will contain a lot of scrambled strings).
HTH,
Mohammed Mahmoud.
royalblues Wed, 06/27/2007 - 03:06
Mohammed,
that was a good info.....rated
Narayan
mohammedmahmoud Wed, 06/27/2007 - 06:06
Hi Narayan,
Thank you my friend, i really enjoy supporting this forum with persons like your self :)
BR,
Mohammed Mahmoud.
drsejjuko Wed, 06/27/2007 - 05:32
when i do a service password encryption? does the vtp password become a victim?
mohammedmahmoud Wed, 06/27/2007 - 06:05
No, the service password encryption affects the passwords saved on the startup/running configuration, and has nothing to do with the info stored in the vlan.dat file.
HTH,
Mohammed Mahmoud.
