VOIP ACL
Jun 27th, 2007
Need your help with HTTPS access.
I use (https://callmanagerIP/ccmadmin) to access the web GUI of CallManager. This way I dont have to access the server via terminal then open Callamanger.
Ive applied the following on the router ACL:
permit tcp 10.70.16.0 0.0.0.255 eq 443 host 10.70.18.1
deny ip 10.70.16.0 0.0.0.255 10.70.18.0 0.0.0.255
10.70.16.x is my PC LAN and 10.70.18.x is Callmanager IP. But is still doesnt work when this is applied on the outgoing interface. When I remove the statement, it works. It seems the the deny on the bottom of the statement is taking affect and the show ip access-list counter increases when the ACL is applied and at the same time me trying to access from my PC https://callamangerIP/ccmadmin
Please help.
Jon Marshall Thu, 06/28/2007 - 02:10
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Try changing your access-list to the following
permit tcp 10.70.16.0 0.0.0.255 host 10.70.18.1 eq 443
Your access-list is saying 443 is the source port whereas 443 is the destination port on the call manager server.
Jon
