Web GUI for CallManager
Jun 27th, 2007
Need your help with HTTPS access.
I use (https://callmanagerIP/ccmadmin) to access the web GUI of CallManager. This way I dont have to access the server via terminal then open Callamanger.
Ive applied the following on the router ACL:
permit tcp 10.70.16.0 0.0.0.255 eq 443 host 10.70.18.1
deny ip 10.70.16.0 0.0.0.255 10.70.18.0 0.0.0.255
10.70.16.x is my PC LAN and 10.70.18.x is Callmanager IP. But is still doesnt work when this is applied on the outgoing interface. When I remove the statement, it works. It seems the the deny on the bottom of the statement is taking affect and the show ip access-list counter increases when the ACL is applied and at the same time me trying to access from my PC https://callamangerIP/ccmadmin
Please help.
MikeTomasko Wed, 06/27/2007 - 05:36
  • Bronze, 100 points or more
Can you post more of your router config, like your access-lists? Do you know which ACL is increasing?
Peter Valdes Wed, 06/27/2007 - 06:00
The callmanager IP address is 10.70.70.1. The deny statement " deny ip 10.70.68.0 0.0.0.255 10.70.70.0 0.0.0.255" is blocking the web access as the counter increases when I try to access and im on the 10.70.68.0 network.
Below is the ACL:
ip access-list extended VOIP-FWout
remark PERMIT ICMP FROM TRUSTED NETWORK
permit icmp 10.0.0.0 0.255.255.255 10.70.70.0 0.0.0.255
permit icmp 172.0.0.0 0.255.255.255 10.70.70.0 0.0.0.255
permit icmp 203.215.128.0 0.0.7.255 10.70.70.0 0.0.0.255
permit ip host x.x.x.x 10.70.70.0 0.0.0.255
remark PERMIT IP Communicator Network
permit ip 10.200.0.0 0.0.255.255 10.70.70.0 0.0.0.255
remark PERMIT TEAM NETWORK IN TO VOICE NETWORK
permit tcp 10.70.68.0 0.0.0.255 eq 443 host 10.70.70.1
permit tcp 10.70.68.0 0.0.0.255 host 10.70.70.1 eq www
permit tcp 10.70.68.0 0.0.0.255 host 10.70.70.1 eq 3389
permit tcp 10.70.68.0 0.0.0.255 host 10.70.70.2 eq 3389
permit tcp 10.70.68.0 0.0.0.255 host 10.70.70.15 eq www
permit tcp 10.70.68.0 0.0.0.255 host 10.70.70.15 eq 3389
permit tcp 10.70.68.0 0.0.0.255 host 10.70.70.10 eq 3389
permit tcp host 10.70.70.254 10.70.70.0 0.0.0.255 eq telnet
permit tcp host 192.168.100.100 10.70.70.0 0.0.0.255 eq 3389
remark PERMIT PCANYWHERE TO WORKSMART CONSOLE FROM TEAM NETWORK
permit tcp 10.70.68.0 0.0.0.255 10.70.70.0 0.0.0.255 eq 5631
permit udp 10.70.68.0 0.0.0.255 10.70.70.0 0.0.0.255 eq 5632
remark PERMIT PBS TO CM SQL FOR CDR
permit tcp host 192.168.100.100 host 10.70.70.1 eq 1433
remark PERMIT SERVCORP NETWORK ACCESS TO UNITY
permit udp 10.70.68.0 0.0.0.255 host 10.70.70.15
remark PERMIT PER DC DNS ACCESS TO UNITY
permit tcp host 10.70.68.10 host 10.70.70.15 eq domain
permit udp host 10.70.68.10 host 10.70.70.15 eq domain
remark PERMIT PER DC ACCESS TO WORKSMART SERVER FOR BACKUPS
permit tcp host 10.70.68.10 host 10.70.70.10 range 135 139
permit udp host 10.70.68.10 host 10.70.70.10 range 135 netbios-ss
permit tcp host 10.70.68.10 host 10.70.70.10 eq 445
remark PERMIT PRINTSERVER ACCESS TO UNITY SERVER FOR SMTP
permit tcp host 192.168.100.100 host 10.70.70.15 eq smtp
remark PERMIT PRINTSERVER ACCESS TO UNITY SERVER FOR LOGS
permit tcp host 192.168.100.100 host 10.70.70.15 range 135 139
permit udp host 192.168.100.100 host 10.70.70.15 range 135 netbios-ss
permit tcp host 192.168.100.100 host 10.70.70.15 eq 445
permit tcp host 192.168.100.100 host 10.70.70.15 eq domain
permit udp host 192.168.100.100 host 10.70.70.15 eq domain
remark PERMIT PRINTSERVER ACCESS TO WORKSMART SERVER FOR BACKUPS
permit tcp host 192.168.100.100 host 10.70.70.10 range 135 139
permit udp host 192.168.100.100 host 10.70.70.10 range 135 netbios-ss
permit tcp host 192.168.100.100 host 10.70.70.10 eq 445
remark PERMIT MANAGEMENT FOR SYMANTEC
permit tcp host 10.70.68.10 10.70.70.0 0.0.0.255 eq www
permit tcp host 10.70.68.10 10.70.70.0 0.0.0.255 eq 443
permit tcp host 10.70.68.10 10.70.70.0 0.0.0.255 eq 2967
permit udp host 10.70.68.10 10.70.70.0 0.0.0.255 eq 2967
permit udp host 10.70.68.10 10.70.70.0 0.0.0.255 eq 38293
remark DENY SERVCORP TEAM IP TO VOICE NETWORK
remark PERMIT VOICE NETWORK ACCESS TO EUROPE SINGAPORE NEWZEALAND
permit tcp 10.0.0.0 0.0.255.255 10.70.70.0 0.0.0.255
permit udp 10.0.0.0 0.0.255.255 10.70.70.0 0.0.0.255
deny ip any any
