Cisco 3835 Router Configuration problem
Answered Question
Jun 27th, 2007
Hi there,
I have an issue with a Cisco 3825 router. When I try to save the running config it shows a paticular error. This same error is displayed when I run the SH START command.
Router#sh start
Using 1826 out of 491512 bytes
%Error opening nvram:/startup-config (Unknown error 0)
Router#
*Jun 27 10:51:36.087: NV: Invalid Pointer value(632F31F4) in private configurati
on structure
*Jun 27 10:51:36.311: NV: Invalid Pointer value(632F31F4) in private configurati
on structure
*Jun 27 10:51:36.311: %SYS-4-NV_BLOCK_INITFAIL: Unable to initialize the geometr
y of nvram
Router#wr
startup-config file open failed (Unknown error 0)
Router#
*Jun 27 11:00:44.331: NV: Invalid Pointer value(632F31F4) in private configurati
on structure
*Jun 27 11:00:44.559: NV: Invalid Pointer value(632F31F4) in private configurati
on structure
*Jun 27 11:00:44.559: %SYS-4-NV_BLOCK_INITFAIL: Unable to initialize the geometr
y of nvram
Router#
Pls can you help by telling me the source of the problem.
Correct Answer by mheusing about 10 years 4 weeks ago
Did you upgrade the IOS lately?
What you also can try:
Router#erase /all nvram:
Router#copy running-config startup-config
It might remove the error messages. Note: erase nvram is not sufficient.
Regards, Martin
Overall Rating: 5 (1 ratings)
olakunle06 Wed, 06/27/2007 - 03:52
The router I'm working on runs Cisco 12.4(11)T. This version is higher than those you mentioned. Could it be the same bug?
royalblues Wed, 06/27/2007 - 04:02
  • Green, 3000 points or more
Could be...
If you can get a downtime, i would recommend upgrading it to the latest available train and check
Narayan
Correct Answer
mheusing Wed, 06/27/2007 - 04:18
  • Cisco Employee,
Regards, Martin
olakunle06 Wed, 06/27/2007 - 06:15
It solved the issue. Apparently, it was an NVRAM problem. Erasing the nvram resolved the problem.
olakunle06 Wed, 06/27/2007 - 05:01
No I didn't upgrade the router. It's a brand new router.
robswanson Fri, 10/08/2010 - 09:14
*Oct  8 17:13:04.835: NV: Invalid Pointer value(45E56768) in private configuration structure
*Oct  8 17:13:04.871: NV: Invalid Pointer value(45E56768) in private configuration structure
*Oct  8 17:13:04.871: %SYS-4-NV_BLOCK_INITFAIL: Unable to initialize the geometry of nvram
Warning: Attempting to overwrite an NVRAM configuration previously written
by a different version of the system image.
Overwrite the previous NVRAM configuration?[confirm]
router#erase startup-config
Erasing the nvram filesystem will remove all configuration files! Continue? [confirm]
[OK]
Erase of nvram: complete
router#wr
Building configuration...
[OK]
