AAA configurations not working
habeeb_talal
I tried to configure my router to authenticate with cisco ACS, but although the router can ping the acs server, i can't login
using the acs user, please have alook to the configuration and help me to find the missing parts
aaa new-model
aaa authentication login default group tacacs+ local
aaa authorization commands 1 default group tacacs+ none
aaa authorization commands 15 default group tacacs+ none
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa session-id common
tacacs-server host 172.x.x.1 key xxx
tacacs-server directed-request
username talal password talal
this is the only configuration i done for AAA, so is there anything else should i do
thanks
5 Replies 5
mahmoodmkl
Level 7
Level 7
First check weather u have added the router as a client in ACS.if not add it.
Next add the below line in the aaa config.
aaa authentication enable default group tacacs+ local enable
Mahmood
Can you add the following commands and try
line vty 0 15
exec-timeout 5 0
privilege level 15
authorization exec default
accounting connection default
accounting commands 1 default
accounting exec default
login authentication default
Narayan
Jagdeep Gambhir
Level 10
Level 10
Hi Habeeb,
Your commands are fine, no need to change it.
-> Please check if you get any hits on acs failed attempts ? If no, then
make sure the shared secret is correct, enter it again, do not copy/paste.
Also add this command on the router,
ip tacacs source interface (IP or interface)
In the above command you need to put the IP that is defined in the ACS , network configuration for the router in question.
If still issue is there , then get me debugs
debug aaa authentication
debug tacacs
Pls rate if helps !
~JG
Next time onward please post this kind of issues in AAA fourm.
Thank you all very much, it is now working after adding the router in the ACS and configure the right key.
Nice to know that.
Please mark this thread as resolved, so that others can benefit from it.
~JG
