CME4-Fallback and CCM 5.12
Answered Question
Jun 27th, 2007
Was looking for the min requirements for implementing CME-fallback on a ISR. Was thinking that I do not need to load any of the CME files (admin, html, phone loads...), just needed the telephony-service configuration. I just want to be able to use the enhanced features during fallback, but not CME itself.
I have looked at the CME4 admin/install guide as well as a Cisco provided CME4-fallback lab config guide and the two definitely do not match up on the requirements.
Thanks.
Correct Answer by Aaron Harrison about 9 years 10 months ago
You just need the configuration elements... not the GUI files/phone loads etc - last thing you want is phones to change firmware every time it fails to SRST.
Aaron
Please rate helpful posts...
Overall Rating: 5 (1 ratings)
Correct Answer
Aaron Harrison Wed, 06/27/2007 - 05:36
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
