I'm trying to use PBR on a Catalyst 6509 whith MSFC2, with IOS Version 12.1(19)E.
I have defined the following PBR
route-map PBR permit 0
match ip address 102
set ip default next-hop 156.106.131.228
The ACL 102 is as follow:
permit ip 156.106.151.0 0.0.0.255 any log
Which simply states for routing all the source to the next-hop IP instead of the normal gateway.
On the interface, I have defined
interface Vlan114
ip address 156.106.151.1 255.255.255.0
ip ospf authentication-key 7
ip policy route-map PBR
The next hop 156.106.131.228 is directly attached to the router via a Vlan.
When trying to monitor it, I see
"policy rejected, normal forwarding"
Any Ideas ?
Tks,
