atm pvc status
Answered Question
Jun 27th, 2007
We have an atm link from delhi to Singapor and we are running ospf on both the router. sometimes neighborship get broken and still it shows atm pvc up and up.when i try to ping from our end to far end router's atm interface it does not ping. I just wanted to know whether problem is in provider's atm cloud or in the router and i also want to knwo the protocol which is used to verify the status of atm pvc
Correct Answer by mheusing about 9 years 8 months ago
You can use ATM OAM cells to verify the connectivity end-to-end. Check "Using OAM for PVC Management" for more details and configuration examples.
http://www.cisco.com/en/US/tech/tk39/tk48/technologies_configuration_example09186a0080094570.shtml
Hope this helps!
Regards, Martin
Overall Rating: 3 (1 ratings)
