AS5350XM ISDN connection encapsulation failed
Answered Question
Jun 27th, 2007
We get the following phenomenon:
A terminal makes an ISDN connection to the AS5350 with an ISDN line that does'nt send its CLID (q931).
The terminal gets connected but the AS5350 cann't route ip packets back to the terminal.
'Debug ip packets' gives as information 'encapsulation failed'
When we redo the same exercise but with a ISDN that presents its CLID we have no problem.
Has somebody an idea what's the reason for this behaviour.
IOS = c5350-is-mz.124-7c.bin
our config:
resource-pool profile customer TERM
limit base-size all
limit overflow-size 0
resource RESOURCE_ISDNPORTS digital
resource RESOURCE_SPEMODEMS speech
dnis group TERM
source template TERM
template TERM
peer ip address forced
peer default ip address pool TERM
ppp timeout idle 70
interface Loopback1
description loopback interface for summarization pool addresses
ip address x.x.15.193 255.255.255.192
interface Serial3/0:15
description ISDN pra interface
no ip address
encapsulation ppp
ip tcp header-compression
dialer rotary-group 1
dialer-group 1
no snmp trap link-status
isdn switch-type primary-net5
isdn fast-rollover-delay 5
isdn incoming-voice modem
isdn send-alerting
no peer default ip address
no cdp enable
interface Dialer1
description async interface for ISDN/PPP calls
ip unnumbered Loopback1
ip access-group security_dialup in
ip verify unicast reverse-path
encapsulation ppp
dialer in-band
dialer idle-timeout 70
dialer-group 1
no keepalive
no cdp enable
ip local pool TERM x.x.15.194 x.x.15.254
ip route 0.0.0.0 0.0.0.0 x.x.0.193
ip route x.x.15.192 255.255.255.192 Null0 200
dialer dnis group TERM
number xxxxx
dialer-list 1 protocol ip permit
Correct Answer by paolo bevilacqua about 10 years 2 days ago
when no mapping is possible with caller number information, PPP authentication is required, but I don't see it configured in above.
Overall Rating: 5 (1 ratings)
Correct Answer
paolo bevilacqua Wed, 06/27/2007 - 14:10
  • Hall of Fame,
    Founding Member
verbruggen Thu, 06/28/2007 - 04:04
This information is new to me, we used to use a competitors device, for which this problem never occured.
PPP authentication isn't an option, hence we will add this requirement into our specs.
Thanks.
paolo bevilacqua Sat, 06/30/2007 - 11:08
  • Hall of Fame,
    Founding Member
I have to correct myself on this.
In lack of clid, is not that you need authentication, but more precisely IP address negotiation. For example, you assign an IP address to the caller from a pool. This way, the router will be able to build a dynamic dialer-map that you can see with "show dialer map".
verbruggen Thu, 07/05/2007 - 03:57
In the config IP negotiation is included pointing to a pool (here called TERM)
I will redo tests and check the dialer map.
First connection (with CLID) gives following input:
Dynamic dialer map ip x.x.15.231 name 7689b366f30f4e55a895207ebe72724a00000000 () on Di1
could it be a bug in the software?
