unable to logon to the 506E while AAA is unaivalable
Answered Question
Jun 27th, 2007
I am unable to access the privilege mode because the AAA is unavailable. Any suggestions?
Correct Answer by JBDanford2002 about 9 years 8 months ago
Are you getting a user prompt? If so try the username: pix and use the enable password for the password.
Overall Rating: 5 (1 ratings)
srue Wed, 06/27/2007 - 10:25
add this command:
aaa authentication enable console RADIUS LOCAL
make sure you have a local user account defined:
username localuser password localpassword
Tshi M Wed, 06/27/2007 - 10:42
I don't have access to the PIX at all. So there is no way to add those commands.
Correct Answer
JBDanford2002 Wed, 06/27/2007 - 10:43
