Robert Salazar Wed, 06/27/2007 - 10:59
Local by-pass allows local calls (calls between voice ports on a router or concentrator) to bypass (not use) the DSP to minimize use of system resources.
ciscoforum Thu, 06/28/2007 - 07:26
Thanks. Just use the following illustration to help me understand. Does that mean if we use bypass the dsp won't be used in the following cases:
1. call between analog 1 and anlog 2 not need dsp at all?
2. Hairpin
scenario1:
analog1-(fxs-r1-pri)-pstn-analog2
scenario2:
hairpin case: call coming into one pri from pstn and route back to pstn using the same pri.
