Hunt Pilot transfer to voice mail
Answered Question
Jun 27th, 2007
Trying to setup a Hunt Pilot for the Main line of a new school. I have it working but when all of the lists have been exhausted, how do I make it transfer to a voice mail box? I even tried forwarding all calls to voicemail and it stil comes back with a fast busy after the designated ring time.
CCM 4.1(3) sr4d
Unity 4.0(4) SR1
IP Phone CP7961G
Correct Answer by Rob Huffman about 10 years 3 weeks ago
Good stuff James! Glad to help :)
Good luck with the rest of your deployment,
Rob
Please remember to rate helpful posts.......
Hi James,
This should be applied at the "Hunt Pilot" Level, if you configure a Destination # (DN of Unity VM Pilot) under the settings shown below, you should be good to go;
Hunt Forward Settings
Forward Hunt No Answer - When the call that is distributed through the hunt list is not answered in a specific time, this field specifies how to forward the call.
Destination This setting indicates the directory number to which calls are forwarded. (This can be the Directory Number of the Unity VM Pilot)
Forward Hunt Busy - When the call that is distributed through the hunt list is busy in a specific time, this field specifies how to forward the call.
Maximum Hunt Timer - Enter a value (in seconds) that specifies the maximum time for hunting.(Used in conjunction with Forward Hunt Busy)
From this good CCM 4.1.3 doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803ed664.html#wp1023973
Hope this helps!
Rob
Overall Rating: 5 (2 ratings)
Correct Answer
Rob Huffman Thu, 06/28/2007 - 08:58
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi James,
Hope this helps!
Rob
Correct Answer
Rob Huffman Thu, 06/28/2007 - 09:54
  • Hall of Fame,
    Founding Member
Rob
