Usage Stats on VOIP calls via IP Trunk
Jun 27th, 2007
Please be gentle, as I haven't worked with IP Telephony for 3 years.
I am trying to figure out some usage stats for our VOIP calls over IP Trunks, not PRI/PSTN connections. We do not have any 3rd Party Call Accounting, so I know my choices are rather limited. Also, this system is being phased out in a year, so we won't be able to put any Call Accounting in.
So basically, I need any usage stats I can get for IP-based WAN calls.
Thanks in advance
paolo bevilacqua Wed, 06/27/2007 - 13:48
  • Hall of Fame,
    Founding Member
Are you using what ? routers, ccm which version, which protocols ?
jackvin Thu, 06/28/2007 - 06:50
Use Cisco CallManager Real-Time Monitoring Tool (it's a plugin from CallManager and you can install it on your desktop). This will give you stats on H323 Trunks, but the downfall is exporting the data. Have you looked at CAR (aka ART)?
