CSS trouble (disk full without useful file)
Jun 27th, 2007
Hi all,
i've got problem with CSS 11150 SW Version: 5.00 Build 63, so i can try to upgrade OS of CSS but after 3 timeout in uploading the disk was full with a part of the OS (i've tried 3 times...). SO now i have not idea about how can i clean the disk...i'm sure i've got a lots useless file but i don't know how see and erase them. How you can see (see below) just one uncompressed OS is present on the system....may you help me?
THK a lot
cssA# show disk
Disk Size: 216 MB
Disk Free: 2 MB
Bad Cluster Count: 0
File Count: 648
Directory Count: 103
cssA# show installed-software
Overall Rating: 2 (2 ratings)
sbilgi Tue, 07/03/2007 - 11:19
I think as you know that, by default, the CSS saves boot and subsystem event log messages to log files on the hard or Flash disk. The content of these files is recorded in ASCII text. You can also configure the CSS to send log messages to an active CSS session, email address, or another host system. The maximum size of a local log file is 50 MB for hard disk-based systems and 10 MB for Flash disk-based systems.
Pavel Bykov Wed, 07/04/2007 - 04:43
On some systems, after deleting a file, you have to use a form of "shrink" command to enable device to use available space. I don't know if that's the case with CSS though.
