How to stop a telnet session in IOS?
Answered Question
Jun 27th, 2007
When I try to telnet but get no reply, if I want to stop the session, is there any way for that? Ctrl+c is not working. Ctrl+shift 6 neither.
Correct Answer by Edison Ortiz about 9 years 7 months ago
If the CTRL-SHIFT+6+X combination doesn't work for you, you can try minimizing the wait with the command
ip tcp synwait-time
lower the wait-time to 5 seconds.
Overall Rating: 5 (3 ratings)
mohammedmahmoud Wed, 06/27/2007 - 12:11
If you are trying to telnet from a cisco router to a cisco router, then use the ctrl+shift+6 then release all and press x, and then type disconnect and press enter.
HTH,
Mohammed Mahmoud.
Richard Burts Wed, 06/27/2007 - 12:12
Yi
Try typing X after you have done the Ctrl+shift 6 combination. That should suspend the telnet that is in process. You can then type disconnect to terminate the telnet.
Rick
hy123 Wed, 06/27/2007 - 12:20
Thanks a lot for the answers.
However, the problem is if the telnet session is not up when the remote end is not responding, there seems no way to stop it, right?
Correct Answer
Edison Ortiz Wed, 06/27/2007 - 12:21
ip tcp synwait-time
hbackus Mon, 05/13/2013 - 14:12
Old post but still valid, thanks to those who went before............
