ACS DB Replcation Fails Through Cisco Firewalls w/Skinny Policy Inspect
Jun 27th, 2007
We run Cisco ACS v3.3 (Windows) on two servers over our WAN, and replcate the internal databases for redundancy. The problem is that replications fail between the ACS servers and it is because of the default port the ACS servers use to replicate over...TCP 2000.
Between the two servers are Cisco ASA firewalls running 7.2.2(19). We run Cisco MGCP VoIP phones between the sites as well, which utilize TCP 2000 for call control.
When the policy-inspect skinny command is enabled on the firewalls, the ACS server replcation breaks, because the firewall sees that the TCP 2000 packets for the DB replication are not VoIP call control packets.
Is there a way to reconfigure the ACS servers so they use a different port other than TCP 2000? (Registry hack, ini file edit, something???)
Frankly, it is rather lame of Cisco to implement an already defined port for their DB replication that defined in IETF as a well know port for the skinny protocol. Even worse is that this problem continues to exist into v4.0 as I understand it.
An no...we should not have to disable the inspect-policy for skinny on the ASA's. :-)
Any help to qwell my frustration on this topic would be appreciated.
-Scott
Jagdeep Gambhir Wed, 06/27/2007 - 16:22
  • Red, 2250 points or more
Scott,
If disabling the inspection of the skinny protocol is not feasible, the following
configuration sample may be incorporated into the firewall configuration so that replication traffic is not affected by the skinny fixup:
In this example, the ACS servers are at IP addresses 10.1.2.3 and 10.4.5.6.
#Define what traffic you want inspected:
access-list skinny_acl extended deny ip host 10.1.2.3 host 10.4.5.6
access-list skinny_acl extended deny ip host 10.4.5.6 host 10.1.2.3
access-list skinny_acl extended permit tcp any any eq 2000
#Create a class map to match the acl
class-map skinny_map
match access-list skinny_acl
#Under the global policy, take the skinny inspection out of the
#class inspection_default, and add it under our new class
policy-map global_policy
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
class skinny_map
inspect skinny
service-policy global_policy global
###Will be inspected for skinny###
FWSM(config-pmap-c)# show service-policy flow tcp host 172.16.1.2 host 172.16.5.6 eq 2000
Global policy:
Service-policy: global_policy
Class-map: skinny_map
Match: access-list skinny_acl
Access rule: permit tcp any any eq 2000
Action:
Input flow: inspect skinny
###Will not be inspected for skinny###
FWSM(config-pmap-c)# show service-policy flow tcp host 10.1.2.3 host 10.4.5.6 eq 2000
Global policy:
~JG
Please rate if helps !
