RME4.0.5 Config Archive Failures
Jun 27th, 2007
I recently installed LMS206 on W2003. On of the first things is to archive the config. I am using TELNET to sync the config with no success when aaa is enabled with local authentication on the devices; when aaa new-model is removed, all succeeded. This might be the username/prompt issue. How can I solve this problem?
I also tried RCP. All failed with error: permission denied. The commands in the switch are as follows:
ip rcmd rcp-enable
ip rcmd remote-host xxxx www enable
where xxxx is local username and www is owner in RME.
any other things I missed?
Joe Clarke Wed, 06/27/2007 - 12:47
Check the DCR credentials under Common Services > Device and Credentials > Device Management for this device to resolve your telnet problem. Make sure that the correct username and password are entered there. If you use custom Username/Password prompts, add them to NMSROOT/objects/cmf/data/TacacsPrompts.ini.
As for RCP, check the username configured under Common Services > Server > Admin > System Preferences, and make sure "www" is the RCP username.
Chuan Liu Wed, 06/27/2007 - 14:04
Thanks jclarke,
I got TELNET work by editing device credentials in RME>Devices>RME Devices.
RCP is still not working. Where is the local-username configured in RME?
Joe Clarke Wed, 06/27/2007 - 15:44
As I said, Common Services > Server > Admin > System Preferences. The default RCP User is "cwuser".
