vitripat Wed, 06/27/2007 - 16:25
  • Gold, 750 points or more
I checked your configuration and SSH is configured-
ssh 65.115.10.0 255.255.255.0 outside
Can you try generating crypto keys as-
ASA(config)# crypto key generate rsa modulus 1024
WARNING: You have a RSA keypair already defined named .
Do you really want to replace them? [yes/no]: yes
Keypair generation process begin. Please wait...
ASA(config)#
Note: you may need to configure domain name for running above command.
HTTP access from outside is not configured for 65.115.10.0/24 subnet, you can use following command-
http 65.115.10.0 255.255.255.0 outside
However, you need to make sure that compatible ASDM image is installed in ASA flash and that ASA is pointing to the correct ASDM image using following command, for example:
asdm image disk0:/asdm-522.bin
Telnet access is not available from outside.
Please try above and let me know if these help.
Vibhor.
mx Wed, 06/27/2007 - 16:29
Thank yo ufor the response Vibhor. I did do a key regen, I forgot to mention that. I can replace it though, no problem.
The asdm image is OK, it works from the inside.
