Firewall or Router for VPN
Jun 27th, 2007
Is it better to use a firewall like a PIX515E or a router like a 1721 for setting up a VPN?
spremkumar Wed, 06/27/2007 - 23:49
What kinda VPN you are talking about ? is it a point to point vpn between 2 sites or gonna be used by remote vpn clients ?
If its a simple point to point vpn between 2 clients then you can go ahead with Cisco 1721 which can handle the same..
But if its gonna be more than one site with that if you are more concerned in your security aspects then go with PIX aplliances.
Otherwise you can settled down with even a higher end router which can solve your purpose..
regds
srue Thu, 06/28/2007 - 05:06
The PIX will probably handle the traffic load better - meaning encryption load.
Also take into account what your NAT policies are for this vpn connection and where you perform NAT already. That might affect your decision as well.
wrwiii122 Thu, 06/28/2007 - 06:26
Sorry I didn't specify. I am refering to client VPN. Is a router or firewall better to use and why one over the other.
wrwiii122 Thu, 07/05/2007 - 05:57
Thats what I thought too but someone I know is saying that a router is a better way to go because it has more features for VPN than a firewall. That's why Im trying to figure this one out and ask the pros. It is a good question.
