Allow Inside Hosts Access to a DMZ without Translation
Jun 27th, 2007
Could you pls mail what exactly the below command will do ?
1) static (inside,dmz) 10.1.6.100 10.1.6.100
2) static (dmz,inside) 10.1.6.100 10.1.6.100
Pls mail me documentaion reference with multiple DMZ(1-4) configuration in PIX with translation and without address translation.
-Ganesh
srue Thu, 06/28/2007 - 08:43
you don't need 2), assuming 10.1.6.100 is the host on the inside interface that needs access to the dmz.
You could also use nat zero to accomplish this:
nat (inside) 0 natzero_acl
access-list natzero_acl permit ip host 10.1.6.100 host dmz_host_ip
gappavoo1 Thu, 06/28/2007 - 09:21
Thanks for your reply !
Pls clarify me, assuming a host 10.2.7.200 in DMZ interface that needs to access inside the below commands is correct ?
static (dmz,inside) 10.2.7.200 10.2.7.200
-Ganesh
acomiskey Thu, 06/28/2007 - 09:37
No you would not need that.
For 10.2.7.200 and 10.1.6.100 to communicate between the inside and dmz, all you need is...
